Old 10-23-2010, 02:02 PM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by NU55TY View Post
Hey guys I have a 95 twin turbo supra, I was thinking about upgrading to the gt28 twin turbo upgrade and increasing the size of the injectors to 600cc and the wastegate to support the 16-28psi boost. Just wanted to know, by doing this, will I have to change the fuel pump and clutch etc or can the stock ones handle it? Is this upgrade worth doing or is it just better to upgrade to a singleturbo? Thanks
  1. Which "GT28 Twin Turbo upgrade". I need to know more - there are too many types of "GT28" turbos to help without more info:
    GT2854R - 471171-9
    GT2859R - 707160-9
    GT2859R - 780371-1
    GT2860R - 707160-5
    GT2860R - 707160-7
    GT2860R - 739548-9
    GT2860RS - 739548-1
    GT2860RS - 739548-5
    GT2871R - 472560-15
    GT2871R - 743347-1
    GT2871R - 743347-3
    GT2871R - 707160-10
    GT2871R - 780371-2
    GT2871R - 743347-2
    GT2871R - 743347-4
    GT2871R - 771847-1
    GT2876R - 705330-1
    GT2876R - 705330-2
  2. The injector size will need to precisely match the max airflow capabilities of the turbo setup. We can determine this by the max horsepower rating of the turbo(s) you choose.
  3. The fuel pump setup will need to match the injector flow rate.
  4. A bigger wastegate allows you to run less boost (not more), with larger turbos.
  5. Again, send me more info on that upgrade you're considering. I need more info to determine whether or not a single turbo would be more cost-effective for you.
  6. What is your horsepower goal? What is your application?
Life begins at 30psi.
