Old 10-20-2010, 04:53 AM   #22
zby67
zby67's Avatar
zby67 is on a distinguished road
Originally Posted by btwilson86 View Post
Oh, okay. Those are the intake plenum's and the throttle body's.
The GE intake utilizes the Toyota ACIS system (info found here), whereas the GTE intake does not. Without this system, you will likely notice a decrease in power.
For example, 7M Cressidas are rated at about 15hp less than GE Supra's. Cressidas use an intake design more similar to the GTE than the GE.
so then vary vary bad idea to put that plenum of GTE on the GE ok thank you for the info! im trying to get the GE up as high as i can with out going turbo. im not one for turbo's.
1986.5 MA70 7M-GE
1987 MA70 7M-GE
zby67 is offline   Reply With Quote
