Old 10-17-2010, 11:39 PM   #2
Sonyps307
All the valves and lashes should be to specs the motor was just rebuild With all new pistons, rods, bearing and the head was redone to. Like a month or so ago just has alittle over 1000 miles on it and just had it first oil change about 2weeks ago and the tapping started around 300-400 miles after the build But I just found out they Torque they head bolts to 58lbs Could this cause any thing and I will check the spark plugs and header bolts tomarrow
