Thread: nuts and bolts
Old 09-20-2005, 08:22 PM   #2
rnoswal
rnoswal's Avatar
Oh well then..................those bolts are easy to find on any other Toyota in the junkyard. The bolts that hold the pressure plate are all the same, 12 mm head, about 3/4 of an inch long. The brackect on the sides are the same as any other front engine rear drive Toyota. They are all 14 mm heads about an inch to an inch and a half long. The bell housings are also 14 mm heads but about 3 inches long. My Supra has the 14 mm head bolts while my 22R 4 cylinder used the 17 mm head sized bolts to hold the bell housing together, never had either one break, but just seemed odd.
The bolts holding the trans mount to the frame where just 12 mm heads on the supra and the ones to the trans had 14 mm heads. The nuts on the lower side if the engine mounts were 19 mm heads and the bolts that held the motor brackets to the block were all 14 mm heads 3/4 to 1 inch in length.
Hope that helps some,
Russ
