about the light on the dash , use a tester and verify the cable using both of them. it should work. if not , removed the one from the negative and place it on another ground and check , if it works , check the sensors on the doors or that job that you did on the dome light , check if theres a loose cable around it. it might came off when you pull it out to fix it. Good luck. Q
ARMY STRONG !!
