Thread: Engine question
Old 10-12-2010, 09:18 AM   #3
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by 92FoxBody View Post
Yup yup. I'd be going with a wet shot and I would have a bottle warmer, nitrous progresser etc. It'll kick at 3K and stop at 6,000 (where I shift). The only thing I'm worried about is possible missing a shift and blowing my motor
I'm not sure if this will help, but we also add in controls based on boost (forced induction) pressure (psi) within the intake system. Boost pressure drops like a stone if you miss a shift, which causes the spray to stop. I'd bet there are measurable differences in intake vacuum pressure depending upon whether or not your n/a foxbody's engine is under load. If so, you could use this to trigger the spray (eg. via a Hobbes switch).
Life begins at 30psi.
