Old 10-09-2010, 03:09 PM   #2
Travis89Turbo
Travis89Turbo's Avatar
160'000 to have bad rings you would need to have putting the wrong oil in for 10 years or somthin??
does the 1j also have a ct26? because there antifreeze cooled. if the seals were gona bad enough could antifreeze be forced into the head??
that is some mean smoke comin from ur 1j
That's not my 1j. thats a buddy of mine. Melted a hole in a piston so its burnn oil with every stroke...
1jz use twin ct12a turbos. but they are antifreeze cooled..
my turbo that went out was on my old 7mgte. it was just the oil seal that burned out. The only way antifreeze would burn from the turbo is if it leaked into the oil passages and the oil seal was burned as well..
160k miles is 257,495 km. So it is definatly not un heard of to have rings go at that many miles if oil has not been changed regularly
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
