Old 10-08-2010, 03:23 PM   #1
Metaphysico
Metaphysico is on a distinguished road
first note the two large fuses you are talking about in the fuse block in the engine bay may the the headlight ones depending on which you are talking about. They only get power when the headlights are on.
A few common problems, starter relay not getting enough power to the starter. And alarm system tripped. First for the alarm system, shut the hood hatch and doors, lock both the driver and passenger door with the key, you should see red security light on the dash come on, after 15 seconds it will start to blink this means the alarm is armed. Then unlock the door with the key to turn the alarm off. This will reset the system if it has been tripped.
Second for the starter problem, take a wire and attach it to the starter signal wire, it is the small wire that is a pain to get to. I just stick a wire into the back of the plastic connector. Then tough the other end to the battery positive terminal. This will engage the starter, so if its a stick shift MAKE SURE ITS IN NEUTRAL. Or a auto make sure its in park.
Lastly give us some more info, do the lights work, does the dash light up and gauges work. Ect. The more info the more we can help.
Metaphysico is offline   Reply With Quote
