Thread: the shakes
Old 10-08-2010, 02:03 PM   #2
Ranma
Ranma's Avatar
Talking
its not the center bearing on the drive shaft??
also what 87 said, check outthe wheel bearings.
would probly be a good idea to check tire pressure, and balancing, all these things could cause wobble and poor gas efficiency.
No the drive shaft was checked out in a shop. So he is pulling the axles and checking the bearings. I threatened to change the registration infomation and named the dealership address as the cars.
I changed the wheels to the factory ones and thus they were balanced. She has had an alignment. IE they changed the inner tie rods and boots just before the rack blew out.
As I said, once is accident, two time is coincidence and third time is comedy. I know where not to buy a new car!
