Thread: Engine question
Old 10-08-2010, 10:38 AM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by Travis89Turbo View Post
Blocks are the same there are 2jzge which is na. And a 2jzgte. Same blocks and heads just different bolt ons for the most part slight differences in them.
Actually not quite. The 2jz-gte has oil squirters, which keep the pistons cooler under boost. Of course, the 2jz-ge also has higher compression pistons (which is worse for forced induction).
The 2jz-gte head is TOTALLY different from the 2jz-ge head (major differences).
Life begins at 30psi.
