Old 10-05-2010, 03:42 AM   #2
btwilson86
Super Moderator
btwilson86's Avatar
Well, if you're sparking that means your timing belt is at least intact (because your exhaust camshaft is spinning). The fuel pump should not prime until your cranking the engine over.
I assume the problem occurred because of how suddenly the engine stopped spinning (from stalling it out). Is your cam position sensor tight? You should not be able to move it at all by hand.
