Of course Meineke wont actually inspect the problem. They went ahead and quote me $645 to change out the rack and pinion system altogether. Said hey if it's leaking it needs replacement. hmmmm
Upon inspection I see the black rubber seals have simply cracked and split apart. On drivers side where leak is, it is coming thru the black rubber seal. Cant they just throw on a new seal? I understand there may be an isuue beneath the seal. But i doubt it would be leaking if the seal was intact.
