Old 09-28-2010, 01:01 AM   #10
Travis89Turbo
Travis89Turbo's Avatar
400mv is not holding voltage... The power on the big cable NEEDS TO BE A SOLID 12 VOLTS. OR 12,000MV. IF IT HAS THAT AND A GROUND THEN CHECK THE SIGNAL WIRE WHEN THE KEY IS BEIN TURNED...AND AGAIN THE DISTRIBUTOR IS NO POSSIBLE WAY YOUR PROBLEM! IT WON'T STOP THE CAR FROM CRANKING.... THAT'S BASIC MECHANICS.. I don't care who's car its on... I m done trying to solve your problem cuz u ain't listening to me.. it would take 1 min to figure if the problem is the starter (i don't care if its new it can still be bad) or wires. A simple 2 wire test..
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
