Old 09-27-2010, 02:33 PM   #1
Travis89Turbo
Travis89Turbo's Avatar
I did this swap 3 yrs ago. The mounts u will need to use is pre 89 and it will drop in. Shifter will end up in the right spot.. as for wiring. There is the c1 plug by the junction block that needs wired.. and the other plugs in the glove box is all the signal wires. some for the gauges and others for the ignition wires (tells it whwn to crank) go to 1jz.com and click on the wiring diagrams andd it will tell u what wires are on the 7m harness plugs and wire colors. Then just get a diagram for your mkii. And match each circuit. The swap isn't that hard but harder then a 1jz in mkiii. Any questions I'd be glad to help.
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
