Old 09-27-2010, 03:09 AM   #21
86.5 7MGE
86.5 7MGE's Avatar
I have found it less traumatizing and easier if you use the 2nd gear instead of the first gear when push starting the car... This method also works if your alarm has enabled and is keeping the car from starting. Oh yea, and do make sure before doing this that your EFI fuse is back in...
Cold Air Intake
MIZU Aluminum Radiator
Ralco RZ Underdrive Pulley
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Techna Fit Brake lines
Clear Corner Turn Signal Lens
Projector Head Lights
Evo Fog Lights
Evo Body Kit
Soon ---> 3'' Exhaust
