Old 09-26-2010, 02:26 AM   #24
Conga1991
Conga1991 is on a distinguished road
I did step on the clutch. Also what do you mean by grounded correctly?? the ground wire that goes all the way to the block and on the side of the bay then Yes. Also I replaced the positive battery cable not the negative.
For the ignition wiring, where do I start to check the continuity? the plug that goes into the starter?
Conga1991 is offline   Reply With Quote
