Thread: Got no spark!!!
Old 09-20-2010, 03:11 PM   #3
porsche944god
porsche944god is on a distinguished road
They relay is still good i moved it to a spot on the inside panel and it clicks....i have power on the "engine" fuse and ecu-ig fuse both sides like i said will run as long as the main relay is jumped will not if everything is like it should be ....i actually while it was running took the ecu-ig fuse out and nothing happened also did the same with the engine fuse. If it is the computer i have no idea how it would have burned up, also doesnt it mean the ecu is bad when u turn on the key and the check engine light does not light up? cuz it did b4 i started tryin find the amp draw.
porsche944god is offline   Reply With Quote
