Old 09-18-2010, 03:44 AM   #2
Travis89Turbo
Travis89Turbo's Avatar
Well here is the magic of a jz engine the block including pistons and rods are capable time and time again of 900hp. the valvetrain however is only good to around 600hp. Plenty for a daily driver.
I didnt do any kind rebuild on my 1jz I bought the front clip and it only had 48k miles on it but they sit for awhile in Japan so I replaced the timing. Serp. Belt. Front and rear main seals. Neither appeared to be leaking nor is there any sign of a leak on the whole engine. I also replaced all vacuum lines and installed a catch can to pro long the life of the the stock twin turbos
2jzgte doesn't have the same problem with the turbos.
Chewbaca rules. But not when ur car mocks him
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
