Old 09-18-2010, 03:26 AM   #1
Travis89Turbo
Travis89Turbo's Avatar
Yes that is very high. I rebuilt my old 7mgte for 2200 I just used oem pistons bored 30 over and went with a new t4 turbo. You should just do a jz swap ur self its really not that hard minus the electrical. which only took me 4 hrs but I do electrical everyday on aircraft. but what a difference the jz is. u can tell just working on it. I did the timing belt an what not just for basic maintince and u can tell. Huge difference in engineering the jz is a lot better built with no weAk spots turbos being the closest weak point and that's only if u try to over boost them. and the use of a catch can for the pcv also prolong the life of the turbos
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
