Old 09-17-2010, 10:32 PM   #20
Conga1991
Conga1991 is on a distinguished road
Originally Posted by ochowdero View Post
the coolant isnt that tricky
go under your car and see if theres grease build up
if there is then power wash the bottom of your car and make sure theres no grease or any fluid for that manner..
wait a day and see if there is any trace of fluid..(on the frame, hoses, panels etc)
should be easier to spot it on the actually hoses and panels its flowing from then the spots on the ground haha
still cant find them i suggest following the coolant cables to find any cracks or nics in them.. if you found one replace the hoses..(with the correct hose!)
I know where the leaks are comig from, how do I fix hem without replacing the hose since its coming from the hard line that goes around the block, I can get do them if I just pull the exhaust manifold off and the intake plenum cuz those are the only two places that are leaking coolant. but the one under the intake plenum is barely dripping coolant unlike the other side whenever i try turning it over it drips like crazy!
Conga1991 is offline   Reply With Quote
