Thread: Clutches
Old 09-11-2010, 10:43 PM   #1
Travis89Turbo
Travis89Turbo's Avatar
No those clutches do not interchange the r154 is a pull type clutch rather then the standard push type... if u have a donor car and u have to pull both trannys might as well put the r154 tranny flywheel and clutch in ur car? Oh and the driveline in it its a little shorter but use the whole driveline and mark it so it goes back exactly the same cuz they are balanced as a whole.... r154 is the best tranny Toyota ever made..almost bullet proof people run over 900hp with them with just an upgraded thrust washer
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
