Old 09-06-2010, 09:01 PM   #3
Bill UK
AEM EMS
Bill UK's Avatar
Try this first; connect a wire (about 15 – 20 amp) to the small spade connector on the starter motor, there are only two wires going to the starter, (both are positive) one large red wire which is bolted on to the starter and one thin one that is connected to a plastic shielded spade connector, (this is where your new wire connects to). The other end of the wire temporally insulate for now, turn on the ignition (make sure its not in gear) remove the temporary insulation from the new wire and touch the positive terminal on the battery. If it does start and you continue to have success, let us know.
