Old 09-06-2010, 06:22 PM   #1
Toyota red coolant. MSD and NGK both make decent plug wires unless you want to make your own... then you can make some monstrous ones.
Just stick with the stock NGK Platinums for the spark plugs, anything else is little more than novelty... iridium lasts longer but is much less conductive.
NEVER cheap out on brakes, and might as well flush the brake fluid system and inspect the calipers and guides.
Check out the belts and while the coolant is drained inspect the timing belt.
