Thread: High idle
Old 09-16-2005, 02:14 PM   #1
rnoswal
rnoswal's Avatar
There should be an air screw on the front side of the intake manifold just right over the butterfly. Try screwing it in some and see if that helps. You might have knocked off a vacuum hose, but that amount of timing sounds like just a turn or so on that air screw should do it for you.
Russ
