Old 09-02-2010, 07:29 AM   #1
Vacationtime247
Sounds like the ignition isn't getting a signal to fire. If your getting fuel, then it's spark related. ECU not sending a signal to the module telling it to fire? Kind of a shot in the dark. But this is where I'd check. Check + voltage in at the module.
VT247
Originally Posted by HotRodV6 View Post
Ok, well after checking everything and replacig what checked bad, i ran out of options and replaced the ignitor/control module and the car still wont start, and has no spark, its getting fuel. Im at a loss with this thing, everything ive checked per the TSRM is good or been replaced, i took the oil fil cap off and the cam is turning like it should so im pretty sure its not a timing belt issue. Any other ideas or help you wish to give would be really appreciated.
