Old 09-02-2010, 07:10 AM   #1
Vacationtime247
Like he said, it's probably the switch at the brake pedal. Had the same problem with mine. Replaced the switch and now its fine. For a temporary fix, just unplug it until you can replace it.
VT247
Originally Posted by rob87 View Post
is it the brake light or parking lights that are staying on? If it is the brake light then check the push button switch that the brake pedal touchs.
