Thread: power issue
Old 08-28-2010, 11:12 AM   #6
Travis89Turbo
Travis89Turbo's Avatar
Originally Posted by brandon bowles View Post
ok i use a bobbi pin and pulled code from car and it is 51. when you first turn the switch to acc. it just blinks real fast. then when you start the car blinks fast still. give the car some gas it acts up and then blinks the code. what could it be?not getting what it means on that page ignition switch
Brandon check out this link...http://www.supramania.com/forums/sho...dle-runs-rough
Have u messed with the tps?
I had a code 51 only whn my KS wiring was bad. I kno its not common but it has happened to others also I tried everything and finally someone said too try re wire so i did and it fixed it. more then likely he has the ac switch on.
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
