Thread: power issue
Old 08-28-2010, 03:33 AM   #3
btwilson86
Super Moderator
btwilson86's Avatar
Originally Posted by Travis89Turbo View Post
I just remembered something make sure ur A/C. SWITCH IS OFF or it will give u false code. 51 specifically. If u still have it with the switch off. thwn re wire ur knock sensors
It'll also give you a false code if you move the throttle, like revving it up... That's likely where your code 51 is from.
Also, when checking codes you do not start the engine. If it is blinking constantly with 1/4 second intervals, then there are no codes present.
Travis89Turbo, how did you gather the OP has a problem with the knock sensor/wiring when there is no knock sensor code present (code 52)?
OP, how much boost are you running? Are you referencing the stock boost gauge or an aftermarket gauge? I have not experienced it, but I agree with Travis89Turbo's first post, sounds like fuel cut
