Now you can have a matching front and rear Arizona Performance Wilwood brake kit with a working parking brake.
If you live in a state or country requires you to pass an inspection proving that your parking brake works, this is the kit for you. It works exactly as the factory parking brake does. You might need to turn the pinwheel adjuster for the drums in, since this will be the same diameter as a NEW Toyota rear drum.
This kit requires minimal rework on the factory cast iron caliper mounting tabs. Similar to the install on the front 13 inch kit a light grinding is all you need. Other than this light grinding, this is a bolt on kit all you need is brake fluid and the proper tools. In my opinion this install is more simple than any of my other installations. Look closely at the photos of the factory caliper mounting tabs.
The kit includes
2, 12.9 inch x 1.25 thick, directional vein, slotted, Wilwood rotors
2, Rotor hats, the center piece (These will include all fasteners installed and torqued) with STEEL brake drum for the factory parking brakes.
2, Wilwood 4 piston "forged" Superlite Calipers
2, Steel Bright Zinc plated Caliper brackets
2, Brake lines "braided stainless steel"
4, Brake pads, Wilwood Street Compound = low dust = excellent cold performance
and all required fasteners and instructions to complete the install.
The price is
$1595 plus shipping and handling.
I have all the parts in stock and can ship within 24 hours.
Heres a link to the front brakes
Here are some photos. Please visit our website, for MKIV or SC300/400 or second Generation GS300 or GS400 kits.
www.ArizonaPerformance.com
