Old 08-07-2010, 05:43 PM   #21
Originally Posted by MA70-3.0GT View Post
...simply whether there's any real benefit to installing a second BOV at only 10psi...
no
...or if it would simply result in a different sound (which is all I'm after really)...
yes
Dual BOV's should have independent vac sources. Running the second with a tighter spring so that is opens a little later and only when there's a stronger signal can also be desirable.
I'll speculate and add that you may notice more of a richness at shifts after this with the auto. The point about auto's is a good one which I hadn't previously considered... thanks for bringing it up.
