I don't think anything is shorting, as infinite ohms is open circuit... (I'm assuming a typo here but did you mean zero ohms/short or inf. ohms/open?)
With the connector for coil 3/5 removed (they unplug seperately under the coil pack iirc) are you getting any signal through those wires with the engine running? (bear in mind CDI signal voltage although short will be probably over 100Vdc and likely easier detected on a scope)
If there is a signal there it's possible the coil itself is u/s, have you checked & compared the 3 coil pack's primary/secondary resistances? it may be easier/safer to prove out the coils by this method.
