Old 08-06-2010, 02:11 AM   #14
Thumbs down
Originally Posted by unkymurch View Post
I don't know the chemistry behind Thermagasket. It would be best to contact them directly.
There is a two part liquid component that is poured into the radiator. There are no solid components.
Okay, so don't act like you do and assume there are not solids involved.... it emulsifies (see: hardens from chemical and/or thermal reaction), like epoxy.... hence... SOLID.
So, the car finally did tank due to something coolant related and you decided not to investigate? Big surprise there.
Products like this can fix TINY leaks in certain types of seals but can also cause significant damages. Use what you wish but I don't want to see this actively recommended on this board.... you got lucky, most 7M HG's blow in a far more spectacular fashion and most owners are obviously far more demanding of their 7M.
Thread Closed.
cre is offline
