Thread: TEMS Lights
Old 08-05-2010, 01:45 AM   #1
Just to make sure there's no short across the cluster illumination wiring, unplug the dimmer and pull the gauge out as far as you can while it's still plugged in. Test for continuity across the white/green stripe wire at the dimmer harness and each of the four wires from the TEMS display.
