so you have your engine smoking at astart up? low compression? is there a milky substance in on your oil dipstick? were about in the motor are you seeing the smoke.
valve stem seals smoke and usually present their problem at startup.
tips and walkthrough for valve stems..
worst case scenario tho
http://www.supras.com/06/techcenter/display.php?QID=5
