Thread: 7m question
Old 07-29-2010, 01:19 AM   #1
I mistakenly thought you were just swapping heads... not the block nor the electronics. You'll need to swap the injectors, distributor and the motor mounts.... there are other electrical differences, but I don't think there's anything else on the engine which is different electrically. There are also differences between the throttle bodies, you may need to swap it if the throttle linkage doesn't reach or over reaches.
