Thread: 7m question
Old 07-28-2010, 04:49 AM   #1
For the most part the heads are all the same (not true by a long shot, but the minor differences across the several revisions will make no difference to 90% or owners). The only SIGNIFICANT difference is that the GE and GTE have different intake cams. So, YES, you may swap them but if one is GTE and the other GE you may want to consider swapping the intake cams and re-shim so that the valve/lobe clearances are according to spec.
