Old 07-27-2010, 03:05 PM   #1
But I don't see my turbo with only showing trace amounts of oil leakage creating a plume of smoke creeping from under my hood whenever I shut my car down.
can we also go over the possibility of a clogged pcv? But I don't really see any of my air hoses being clogged. its possible tho.
as always, thanks for any input and guidance.
thanks in advance
Green7mgte.
that would be the right side actually. it's decided from the perspective of the seated occupant.
the outside leak could be coming from the distributor.
actually, oil exiting into the intake indicates the pcv is doing its job... if there is a lot you may have excessive blow by.
