Old 07-24-2010, 07:10 PM   #2
Originally Posted by btwilson86 View Post
I've read on here about a year ago that the bolt holes aren't quite in the same spot between the 2 bumpers, and that some mild modification would be needed...
That's true and drilling a dozen new holes into a reinforced, high tensile steel is HORRIBLE!!! If you want to swap bumpers just swap the support too. You'll also need to swap the nose piece.
