Thread: vaccume leak
Old 09-11-2005, 03:46 PM   #2
mazzer
mazzer's Avatar
mazzer is on a distinguished road
Originally Posted by toosuped88
my tach doesnt work yet because i motor swapped so if i had to guess i would say it is idling around 500. and yes my engine light comes on intermintently. where is that air fuel adjust screw you were talking about?
the base idle screw is NOT an "air fuel adj. " screw . it simply raises your idle by means of slightly opening your throttle plate.(not suggested)its safe to say you have problems somewhere else.and to answer another question of yours a vacuum leak will cause a lean condition..
3"elbow back,massaged head and manifolds. other minor mods....
mazzer is offline   Reply With Quote
