Old 07-05-2010, 06:42 PM   #4
Green7mgte
Supra Forum Moderator
i would probably inspect the #3 valve cover gasket. but if that was the case he would defiantly see pooling in the galley.
and if your burping your car every 5 minutes.. were are you sucking all this air into from? perhaps you have a cracked rad.
valve stems usually present their problems at start up.. "usually"
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
