Old 07-04-2010, 09:24 PM   #1
wstanek
wstanek's Avatar
wstanek is on a distinguished road
well if you did everything properly it would not have blown! i have a couple wuestions did u tourque the head to the stock specs or to the new specs people have forund for each type of gasket because if u use the stock specs then you probably will have issues and also if u take surface off the head and block you will need a thicker head gasket to compensate for that missing material
1987 N/A 7MGE manual transmission slight rod knock never driven it yet... legally~
wstanek is offline   Reply With Quote
