Old 07-01-2010, 04:08 AM   #1
btwilson86
Super Moderator
btwilson86's Avatar
Originally Posted by BlackMK3 View Post
therefore my thermostat it just stuck open which is why my damn coolant was low
I'm not understanding the logic here.... The thermostat is a mechanical device, as it gets warm the spring contracts and opens it up allowing coolant to flow past it. This would not cause any coolant loss.
Only few ways to lose coolant; you're leaking it, you're burning it, or something's drinking it... Either way, look for wet spots, fill the overflow/radiator, park it uphill and burp any air out of it!
Oh, and fix your sensors/connectors. If you have to I believe you can order pigtails of the wiring harness from Toyota or a parts store, same with the sensors.
