Old 06-25-2010, 01:16 PM   #2
what i would do, if clean the block surface as good as you can with some break cleaner (gunk) and make sure that surface is too good to eat off of...
also clean up anything you would not be able to reach with the head on...
it all depends on what YOU want to do with the car.
also that oil leak may have been a hg or it may not have been.
most common spot if the cam towers my friends went about a month ago...
also heard if you dont rtv your cam towers WITH new gasket there gona leak...
another possiblity is just your valve covers, obviously there removed, just grab some gaskets for them also and rtv them up aswell!
make sure to use a good heat rated rtv or other on all your engine component...
