Old 06-24-2010, 05:05 PM   #1
Stanghunter
Stanghunter is on a distinguished road
Originally Posted by btwilson86 View Post
KS= Knock Sensor
Alot of times, the code 52 is from the KS wiring, and not from the KS itself. Usually rewiring the 2 KS on a Turbo Supra (or 1 on a N/A) will correct the problem. Here is the step-by-step rewire page, and here is a thread in this forum discussing the rewire.
And make sure you have that negative battery cable disconnected or you pull the 15 amp EFI fuse out for a few minutes to erase the code from the computer.
Thanks for the response!
What goes wrong with the factory wiring that we need to rewire the KS?
Stanghunter is offline   Reply With Quote
