Thread: Gear box rattle
Old 06-23-2010, 03:27 AM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by mrgdm007 View Post
Hey so I have a 94 supra tt, 100k 6speed, and just had a lightweight fandanza flywheel put in and now am getting rattle from the gearbox, I did not have it before but the mechanic said its just annoying but it wont harm anything, my questions was has anyone else had this problem? And if I switched back to the stock flywheel would that fix my problem?
It's totally normal, and won't harm anything. Everyone that has switched from the oem dual-mass flywheel to a solid (one-piece) aftermarket flywheel has had this noise. It's usually worse with the a/c on. It comes from the hearing gears in the transmission 'slapping' against each other whenever the rpm in the engine changes (which is very frequently). An oem dual-mass flywheel eliminates this noise by absorbing the rpm changes - the dual-mass flywheel is two independently-rotating pieces connected with springs, so rpm changes are absorbed by the flywheel. The heavier oem flywheel also makes the car easier to drive, at the expense of rpm responsiveness...
Life begins at 30psi.
