Thread: Canister???
Old 06-19-2010, 06:39 AM   #1
Originally Posted by joshtexican View Post
by the way
What goes in place of that canister on a 7mgte??
Nothing. The GTE and the Cressida's GE weren't lucky enough to get that system. It provides a second torque/power scale by modulating the intake acoustics (basically it's a trick of physics that allows the effect of multiple length runners without all the extra components and valving). It switches between modes (per Toyota's literature) at about 4000RPM thus providing you with more power and torque in the lower RPM than the engine would otherwise see (such as in the Cressida)... it's not so much an issue with the GTE as it begins building boost around 2K RPM (yes, the manifold pressure coming up to ambient pressure IS still boost)... so people forgive the sluggishness below that... besides... who ever drives with the RPM below that when they're trying to move fast??
The GTE and GE are the same block. The GTE just undergoes more machining after casting. Both have the three bosses for knock sensors (but GTEs will only have two drilled and tapped and GE will only have the middle one drilled and tapped), both have the bosses for the turbo oil feed and drain, but again, not drilled and tapped on the GE and so on.
