Old 06-19-2010, 05:25 AM   #2
turbonicsperformance
turbonicsperformance is on a distinguished road
Originally Posted by 2.5RHDsupra View Post
Yeah the harness broke but one of the wires inside the harness is broken, not the actual wire, but the connector part, if that makes sense.
find the lock on the metal prong that goes into the connector (the piece your showing us) it will have a small lock or basically a pertruded piece of metal coming off of it just bend it out more and insert it back into the original plug and for extra strength add a dab of superglue to it ive done it a hundred times and have never had one fail a second time
92 miata 7mgte swap forged pistons,studded mhg, 3 inch dp with a glass pack,blowthrough MAF-T,550cc inj, act stage 2 clutch, fmic kit, greddy rs, full wire tuck, rx7 lsd rear with 4.10s. 15psi "ct26-A"??(waiting on dyno #s) if anyone knows whats up with my turbo let me know it has a larger comp wheel nicer machining and 6 dual fins rather than 5? its confusing and keep finding too much contradicting info. would LLLLLOOOOOOOOVVVVVVVEEEEE a compressor map
turbonicsperformance is offline   Reply With Quote
