Thread: Electric Fan?
Old 06-18-2010, 03:06 AM   #16
batmmannn
batmmannn's Avatar
Default Ok
Please understand I have an NA NON turbo. The fan is on the radiator it does not cool the condensor. I can't seem to get a straight answer as to if the fan not working can allow the car to overheat, from what I have read it is tripped either by the AC or the Temp sensor. Mine does not work at all, works if I hook it up direct to power, I swapped fan relays from my other car NO DIFFERENCE. Where do you guys run wires into the cab so I can switch this fan, I see no easy openings on the firewall. I don't have fans on my condensor I have one big 8 inch electric fan shrouded against the radiatior on the motor side just like an older MK2 celica supra non turbo. Thanks for your help I broke the tang thingie off my thrromostat and now am about to drill it.
