Thread: I Need HELP!
Old 06-16-2010, 12:57 AM   #1
Originally Posted by steve0490 View Post
I used a mac machine with the asian imports cartridge and its prety acurate. I mean I was old to check the witing harness for a broken wire. I did and there was none. I was told to check fuses but I don't have the panel cover to see what's fuse is what. I was thinking maybe the ecuj is bad considering my power cable groujnded out one time, and the ground once had a bad connection constantly killing power to the car. Is that a possibility it messed up the ecu.
Never heard of it and there's no way of measuring the voltage to the ECU without pulling the glovebox on the MKIII and simply measuring it at the ECU. The B+ and B1+ lines aren't routed out to the diagnostic box. I'd like to see pictures of what you're using, please.
And no, it's HIGHLY unlikely that you've killed the ECU with an external short to ground... it's a pretty robust beast.
You didn't answer my question either.. do you have any diagnostic codes? (do it the way Toyota does and just use the jumper as detailed in the Toyota Service and Repair Manual; see the FAQ section, there's a thread on how to do it).
EDIT: Wait, do you mean something by MAC Tools? Okay, I've heard of them.... still no idea what the device thinks it's reading though. Have a model number?
