Old 06-13-2010, 06:23 PM   #1
turbonicsperformance
turbonicsperformance is on a distinguished road
Originally Posted by sassan View Post
not that i know of everything is still stock and still there
the springs in your speedo are shot or your speedo gear has been swapped/ your rear gearing has been search the forum for "rear gear change" there is a table that says how fast you should be going at what rpm
92 miata 7mgte swap forged pistons,studded mhg, 3 inch dp with a glass pack,blowthrough MAF-T,550cc inj, act stage 2 clutch, fmic kit, greddy rs, full wire tuck, rx7 lsd rear with 4.10s. 15psi "ct26-A"??(waiting on dyno #s) if anyone knows whats up with my turbo let me know it has a larger comp wheel nicer machining and 6 dual fins rather than 5? its confusing and keep finding too much contradicting info. would LLLLLOOOOOOOOVVVVVVVEEEEE a compressor map
turbonicsperformance is offline   Reply With Quote
